Fixed width spreadsheet string to array
Sorry for the (very) delayed response. I have been busy and had computer issues.
@altenbach wrote:
This does not sound right.
Can you explain a bit more?  "You are wrong" is not exactly helpful 🙂
Message 11 of 19
(3,699 Views)
BowenM wrote:
To this note, I plan on actually doing the loading inside of an "in place element structure" that uses a data value reference, and a message handler passing that reference in order to keep track of what is writing/reading the data when.  This will be done with a producer-consumer state machine architecture.
(sorry, I was posting by phone earlier).
Maybe you could use a few more sentences to explain in more detail what you are trying to do.
What is the purpose of the message handler? Access to DVRs is already blocking and prevents concurrent access to the data.
Message 12 of 19
(3,682 Views)
I see the reason for the confusion. I misspoke in my description The queue will handle just the state, not passing the reference.  Here is a very (very) rough example of the basic architecture I'm considering. Picture is worth a thousand words and all that...
Message 13 of 19
(3,668 Views)
I'm exploring a potential solution using the "scan from file" function, but knowing how your headers are formatted would be very helpful. Could you possibly post an example header (or even an entire dataset)?
Message 14 of 19
(3,644 Views)
Unfortunately, I can't post any data. As for the format, it would be something like the attached .txt file.
Edit: To be clear, both of the other methods in this thread ended up working, but they both relied on me having prior knowledge of the column width (10).  Without this knowledge, it becomes far more difficult, and I wasn't able to solve it in a way that was even close to effecient. It took way too much text parsing.
Message 15 of 19
(3,632 Views)
Here's an example that bypasses loading the numeric values to strings as intermediaries. It accomodates an unknown number of columns of unknown widths, and an unknown number of rows.
It does have some limitations:
The columns must all be of the same width
The data file must have a separator between the header label and data of the form "---    "
It becomes inneficient with very large header files
The .vi is attached as well. Snippet is good for LabVIEW 2011 and the .vi is good for LabVIEW 2010.
As always:
Any attached Code is provided As Is. It has not been tested or validated as a product, for use in a deployed application or system, or for use in hazardous environments. You assume all risks for use of the Code and use of the Code is subject to the Sample Code License Terms which can be found at: http://ni.com/samplecodelicense
Message 16 of 19
(3,604 Views)
I dont like the Read single character, it must be inefficient. Read the full first line and parse the text. Check the snippet, this'll give a list of column names and their offsets, so it doesn't even need to be the same width. Currently it doesn't allow spaces in column names.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 17 of 19
(3,587 Views)
Yamaeda,
Thanks for looking it over. While writing this, my biggest concern was the efficiency of reading in the actual data (since it's a significantly smaller portion of the file), but I may have had a touch of tunnel vision and wrote the code specifically for his example file. Looking back, there is definitely room for improvement in the parsing/processing of the header.
Another shortcoming I didn't take in to account is that with my code you can't use a hyphen in the text preceding the dividing row. By reading an entire line as you suggest, you could also check to make sure that the line only contains spaces and hyphens.
I haven't done extensive performance testing on this, but one more potential area for improvement that I didn't mention is parallelizing the nested "for" loops where the data is actually read in. This would likely  increase memory usage slightly, but on a mutliple core machine may speed the process up significantly. I interpreted end goal as being more important to conserve memory than processing power, but if that's not the case it's definitely an area to explore.
I may end up doing some more thorough testing on this and then posting something along these lines to the code exchange. If so, I will definitely take your suggestions in to account.
Message 18 of 19
(3,580 Views)
Disk access cant be parallellized. 🙂
/Y
Qestit Systems
Message 19 of 19
(3,577 Views)
