Fixed size Table Control: prevent "scroll on Enter" behavior
I have a table control which will always be 6 rows by 8 columns.  I wish to prevent the display from scrolling which would display one or more blank lines at the end of the table.
I have tried turning off "Selection Scrolling" in the right-click menu and disabling "Show vertical scroll bar" under Properties - Appearance.  However, even with both of these settings, if the user makes an entry in the last row and presses the Enter key, the table scrolls up one line and exposes a blank row at the bottom.
Is there any way to suppress this behavior?
(5,446 Views)
Accepted by topic author mistercat
(5,442 Views)
Your suggested solution looks doable but is more complex that I had hoped (all scrolling OFF, for instance).  I think the change-all-"Enter"-to-"Return" version is what I am looking for because users will be changing very few entries and I never want Enter to put the cursor on the next row.
Thanks for your quick response and pointing me to a thread rather than just your solution.
(5,437 Views)
