Fix tick number on a chart
Hello everyone,
I want to fix the number of ticks on a chart.
Actually, I want show 5 ticks on the chart.
Thanks for your help!
(2,704 Views)
Try this:-
http://forums.ni.com/ni/attachments/ni/170/490806/1/SNAG-012.jpg
Thanks as kudos only:)
(2,700 Views)
@Xiang00 wrote:
Hello everyone,
What do you mean by Tick?. Is that a data point you mean to say so you have only 5 points visible and keeps running in the chart?
(2,692 Views)
Hi Xiang,
               You can use the properties of the graph to set the number of tick marks.You can set the range also,that is you can set the major or minor ticks
X Scale->Range->Minimum, Maximum, Increment, Minor Increment.Hope this is you are trying......
(2,688 Views)
