Fitting Gaussians with similar Means but different amplitudes/standard deviations
Hello All,
   I'm trying to figure out how to fit my data with a summation of Gaussian curves some of which may be hidden by others.  I have played with the 'Non-Linear Curve Fit VI' but I run into a problem when I feed it data that has the addition of two gaussian curves with similar means and different amplitudes/standard deviations.  Has someone figured out a means of deconvolving similar gaussian peaks into their summated parts?
(2,983 Views)
While it can be helpful to see the error message, it is much more helpful to see the code ...
BS
(2,955 Views)
