Fitting 1D array to a double-peak gaussian function
Hi LabVIEW experts!
I am rewriting a MATLAB code into LabVIEW code. I am stuck at this following part:
(MATLAB code)
x=1:770
y = current_frame_1D
options.StartPoint=[amp1, pos1, Lim_mean1(3), amp2,pos2, Lim_mean1(3)];
options = fitoptions('gauss2','Lower',[Lower_Lim1,Lower_Lim2], 'Upper',[Upper_Lim1,Upper_Lim2],'TolFun',1e-2,'TolX',1e-1);
G_fit = fit(x.',y','gauss2',options);
The gauss2 parameter in the MATLAB fit function aims to fit the data following this equation:
Y = a1*exp(-((x-b1)/c1)^2)+a2*exp(-((x-b2)/c2)^2)
Which is a sum of two Gaussian curves.
Is there a way to do this in LabVIEW? (I can only see the Gaussian peak fit.vi, which detects 1 peak only...)
Thank you!
(6,116 Views)
Accepted by topic author bazingagirlsun
The Fitting Palette has a Nonlinear Curve Fit function that uses the Levenberg-Marquardt algorithm to fit an arbitrary (in your case, sum of two Gaussians) function.  Nonlinear curve fits are something of a black art -- if you haven't used LM before, I'd do a little reading about it (use the Web).
Another method to do such a fit is the Simplex method.  There is a Downhill Simplex nD VI on the Optimization Palette, but when I tried to understand how to use this for an optimization/curve-fitting problem of my own, I gave up and wrote my own Simplex algorithm in LabVIEW.  I don't know if it would work for your data and model -- if you can attach a data file, I might give it a try ...
(6,085 Views)
Start with this and modify as needed (also read the rest of the tread).
(6,075 Views)
Yes, the stock downhill simplex is in the optimization palette, not under fitting and it also does not accept a VI model (The code is also a bit ugly ;)). Similar to you, I wrote a nelder-mead simplex fitting VI that is "pin compatible" with the nonlinear fit (VI-model). It converges definitely slower than lev-mar. The advantage of nelder-mead is that it does not require partial derivatives so it can deal better with functions that are not very smooth (e.g. based on an iterative procedure). That's not a problem with Gaussians.
(6,074 Views)
Thank you for the suggestions! The fitting is still not working, (but I have other bugs in the vi, so I am troubleshooting one-by-one right now).
I also found the Sum of 3 Gaussian Model in the LabVIEW Examples, and I am going to see if minor changes to that code will accelerate my application...
(6,024 Views)
