Fit random hole
For a control of punched steel-strips, I need to measure (size and position) all the holes that are punched.
The holes have different shapes. Round, oval, slot or keyhole.
I take pictures during the throughfeed of the steelstrip and I have to process them at +/- 5Hz.
I need to find all the holes in my pictures, and find out what - kind of hole it is
        - the size of the hole is
        - the position of the hole is.
Taking the pictures, fitting a round hole, measuring the position is no problem.
But I can't fit an oval hole, a slot or a keyhole. Let alone that I have to find out what kind the hole is ... Smiley Sad
Does anyone has an idée of how you can start on this...
Thanks in advance!
(2,653 Views)
If you're using Vision, I guess BLOB analysis is you key answer.
You can find multiple examples in LabVIEW om how to use this.
Kind regards,
Bjorn Conjaerts
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
(2,590 Views)
