First character left in file when reading first line in text file
When using the function Reading from Text File  a file  I notice that the 1st character is left in the file. I read the line correctly.
When appending a 2nd line that character is in the file.
Attached is part of the code vi.
Any ideas ?
Thank you.
Elik
(3,518 Views)
Accepted by topic author Elik
Can you attach an actual data file and tell us what you mean by "first character". How many characters do you have per line?
Can you tell us what you see in the modified file and what you expect to see.
Everything looks right.
  1. You read the first line and thus the file pointer is right after the first line
  2. You set the file size to end(seems useless, because it does not do anything). The file pointer is still right after the first line.
  3. You write the first line you read concatenated with a second line. This will be written at the current file pointer, i.e. after the existing line
  4. The first line is in the file twice, as expected.
Setting the file size to "end" on an existing file does not do anything useful. Could it be you want to set file position instead?
Try to set the file position to start and the new data will be written from the beginning of the file.
Message Edited by altenbach on 05-28-2009 05:41 PM
(3,511 Views)
The 1st line for purpose of demostration is Line 1.
After reading the file and concatenated  with Line 2 the file looks like this,
LLine 1
Line 2
The 1st character of Line 1 stays after read and when I write back the concatenated   strings that is the final results.
I'll try to set the file pointer to starts after reading.
Thanks.
Elik
(3,494 Views)
Thank again. Setting to start did the trick.
Elik
(3,493 Views)
Then please mark Altenbach's message as the solution rather than your Thank you message.  You can unmark your message by going to the Options menu to the upper right of your message.
(3,484 Views)
My mistake. Sorry about that.
(3,461 Views)
