Fire a Event when a particular channel data buffer overflows
Hi all,
     Here i am using Trio motion coordinator hardware to control through labview, i was using Trio Activex Control, when i receive the data  Asynchronously from the motion coordinator in a particular channel it gets overflow. so that in a reference manual it has mentioned that i need to fire up a event, when the data buffer overflow takes place in a particular channel.
But before that i need to get some clear idea to how to use the Reg event callback function in a labview
I will attach you a user manual regarding the Trio motion and page no.8-39 (Activex Control events)
Please give me any possible solution to access.
Thanks in advance
Dinesh
(2,427 Views)
Did you search the Web for "Register Event Callback LabVIEW"?  I found several articles, but as I try not to use ActiveX, I don't have any experience with these methods.
(2,379 Views)
