Finding the x value where a y value crosses a threshold in a chart
When creating a plot of a curve derived from measurements, I need to find the x value for the point where the curve goes above a given value on the y axis (e.g. 50) - or at least the closest x value for the next y value above that crossing . Judging from the LabView documentation, the limit test vis do not give the x value I need. How can i accomplish that? Maybe this can be done using MathScript?
(4,308 Views)
The Threshold 1D Array function will do that, assuming your data is monotonically increasing.
(4,306 Views)
There exists an example for what you would like to do.
Under the Help Menu, do a search for Waveforms (with an s - plural).
You should be able to find an example called "Search Waveform Example.vi".
It looks like the image below:
RayR
Message Edited by JoeLabView on 06-15-2008 01:44 PM
(4,305 Views)
Thanks!
That indeed was just what I needed. I wasted half a day looking for something like this, but obviously in all the wrong places 😞
Cheers,
Bernhard
(4,280 Views)
Two good places to look for info and examples are the Example Finder (Help > Search) and this forum..  🙂
Usually, solutions are easier than people think.  Glad to read it helped.
RayR
(4,270 Views)
If you look at this example, it looks to me like it is missing a whole load of crossing indices.
Has anyone take a closer look at this?
I also need a VI that is the equivalent of threshold 1-d array, but works for oscillating data.
Any thoughts?
Don
(3,973 Views)
Anyone had a chance to take a look at this example to verify that it is not working properly, and whether it will be corrected?
Don
(3,952 Views)
