Finding lines (not straight) in an image
Hello!
I am a student doing a task to inspect for holes in a fish net by using machine vision. I have successfully developed an area-based algorithm but need one more. My struggle is: I am searching for a way to find out if the lines/curves in the net are somehow "not finished". I am struggling because the net is continuous and it is hard to make a particle analysis because of this. Does anyone have an idea of how to do this? I hope I have explained well.
A picture of an example of a net is added here:
(3,413 Views)
Could you count the nodes of the net and compare this to an expected value?
The Harris Corner Detector
works quite well on chessboards;
https://en.wikipedia.org/wiki/Chessboard_detection
(3,384 Views)
Well, maybe that could be an possibility! The problem is that we are designing machine vision for a dynamic system. The expected value will probably change. Thanks for your suggestion!
(3,373 Views)
Could you upload your VI to see what you've done thus far? That way, we'll be able to run your VI and be able to give suggestions.
(3,366 Views)
