Finding RMS value of Sensor output( alternating sinusoidal voltage varying b/w 1.5 to 3.5)
I am reading current sensor output which is alternating sinusoidal voltage (varying b/w 1.5 to 3.5) using labview interface for arduino....how can i find the rms value of this signal?.....i am not able to connect RMS block to sensor output.....error message is that no connection possible b/w double & 1D  array.....how can solve this problem
(2,751 Views)
Look for the RMS PtByPt.vi (e.g. via Quick Drop), and you can do your RMS calculation on the fly.
Regards, Jens
Kudos are welcome...
(2,744 Views)
