Finding Front Panel Control indexes
Is there an easy way to find the Control Indexes of all the Front Panel controls?  I know I can create do this individually for each control using the Control Index property node.  I was wondering if there was a function or a way to read all Front Panel Control Indexes a lot more efficiently.
Thanks so much!
Message 1 of 13
(6,518 Views)
Why do you need the indexes? Maybe there's a leaner way aroind the problem.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 13
(6,514 Views)
I need to re-initalize all my front panel controls except for a select few.  I was wondering if there was a function or an efficient way to programitically read out all the front panel control references.  I then want to set specific control values to certain values using the "Set Control Values By Index" function.
Message 3 of 13
(6,503 Views)
How will you identify which ones you don't want to change?  If you're going to do it by their name, this?
Jim
Message 4 of 13
(6,492 Views)
Yep, using the control index property node.
Message 5 of 13
(6,472 Views)
Message 6 of 13
(6,470 Views)
Picking up on Yamaeda's suggestion, I just wrote a routine that had a Picture control that I wanted to fill the full screen.  At first, I went through and made each control except the Picture invisible.  Then I had an "Aha" moment -- I used the Pane property to get references to all of the controls, made them all invisible, then went through looking for controls whose ClassName was "Picture" (I could have also used the Control name, but this seems more direct) and did what I needed to do with it.  Much neater, no muss, no fuss.
BS
Message 7 of 13
(6,458 Views)
Does this do the trick?
Cheers,
mcduff
Message 8 of 13
(6,451 Views)
Thanks McDuff and Bob_Schor...This information is very helpful!
Message 9 of 13
(6,395 Views)
Then you can invoke the Reinitialize default values and rewrite the select few. 🙂
/Y
Qestit Systems
Message 10 of 13
(6,389 Views)
