Finding Default Web Browser
I am looking for a way to find the default browser on a machine and open an
HTML test report from disk. I have a vi that I downloaded that was written
using a CIN that does exactly what I need, however it only works about 99%
of the time. Sometimes it just doesn't load the browser or the page. I can't
debug the vi because I don't have the source code. If anyone know the
mechanics of how I can find the default browser I would like to attempt to
create one using native Labview.
Kevin
(3,250 Views)
If you look in the help directory, there is an LLB called _browser.llb. It
might be in a subdirectory called intlinks. This LLB has a VI in it for
opening a web page in the default browser on your system. It is what LV
uses to implement the internet links in the help menu.
Give it a try.
Greg McKaskle
(3,250 Views)
Hi Kevin
The way I did this was to open the HTML file using (on the Mac) Finder - the
equivalent on the PC would be Explorer. It opens the HTML file with whatever
program is associated with the HTML file.
On the Mac, I obtained the Target ID of Finder (Communication:Apple Event:Get
Target ID), and supplied this together with the full path of the HTML file to
Communication:Apple Event:AESend Open Document.
On the PC, you would simply wire the string "explorer.exe filename.html" to the
"Command" input of Communication:System Exec. Something like this would work
on UNIX too.
Paul
> using a
> Thanks
> Kevin
Research Assistant
School of Physiotherapy, Curtin University of Technology
Selby Street, Shenton Park, Western Australia, Australia. 6008
email: P.C.Davey@curtin.edu.au
Tel. +61 8 9266 4657 Fax. +61 8 9266 3699
"Everyone who calls on the name of the Lord will be saved." Romans 10:12
"For all have sinned and fall short of the glory of God, and are justified
freely by his grace through the redemption that came by Christ Jesus." Romans
3:23-4
(3,250 Views)
