Find position
I have several huge files. The problem is when I would like work with them, it's very long.
That's why, I try to search the position in the file. It's a same principe when you search one word in a dictionnary. If you search the word "painter" you known it's after the middle of the dictionnary.
Therefore you go directly in this section.
I would like apply the same idea but instead of a word I'm looking for dates. But it doesn't work.
You can found in attachment my vi.
Thank in advance.
Message 1 of 21
(5,792 Views)
I believe your looking is called a binary search. for the principle just type that into google
i have found an example on this site but have not looked into it to see how applicable it is too you tho
http://zone.ni.com/devzone/cda/epd/p/id/220
hope it helps
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
Message 2 of 21
(5,789 Views)
Hi kourte,
maybe the problem is your mixing of the state enum with some file position numbers in case "1" of your case structures?
I suggest making that enum a typedef!
Message 3 of 21
(5,788 Views)
Helo Akiel and GerdW,
Thanks for your help.
hope it helps
 I have try this solution before but doesn't correspond completely to what I want.
GerdW a écrit :
Hi kourte,
 Oops, I have change one thing before send the file and I don't see it change my enum. But the problem comes not from here.
Message 4 of 21
(5,775 Views)
Hi kourte,
"Oops, I have change one thing before send the file and I don't see it change my enum. But the problem comes not from here."
I do believe that's part of the problem when you screw up your state machine like this!
Message 5 of 21
(5,761 Views)
Hello GerdW,
yes it's a part of my problem, thanks. I have correct this error but it's around in circles... I get no result
Message 6 of 21
(5,759 Views)
Hi kourte,
you still screw up your statemachines.
In case 1 you don't provide a new state but instead wire the file position as new state. I believe this will not work...
Message 7 of 21
(5,752 Views)
Hi GerdW,
I have considered your comments but I have no information that appears.
Do you see why?
Message 8 of 21
(5,717 Views)
Finaly, I successful to display informations on my array but it don't display the good information...
Message 9 of 21
(5,703 Views)
someone has an idea ???????
Message 10 of 21
(5,671 Views)
