Find maximum
Hi All,
 I need to find the maximum values of a data stream I am pulling off a load cell. My experiments last for hours, so I currently decimate my data to generate smaller data files and then do some post processing in matlab to find desired values (i.e.. Maximums, minimums, etc.)  What I would like to do is pull off the maximums before I decimate my data and store them.  On any given experiment there might be 3 to 10 overall maximum values I am interested in.
Thank you
(3,364 Views)
Are you looking to find peaks or maximum? If you are just looking for maximum value, in one set of data there will be only one maximum value and you can use 'Array Min Max' function for that. If in a set of data you are looking for peak values (which could be multiple values based on the threshold value you pick), use 'Peak Detector' function.
Kudos are (always) welcome for the good post. 🙂
(3,360 Views)
If you look in Array palette, you will find an Array Max & Min.  Will this do the job for you?
(3,359 Views)
Thanks for the quick reply.
Yes I should rephrase, I am looking for multiple peaks in my data.  Not the overall maximum.
 I will try Peak Detector, the only thing I am worried about is that my threshold will always need to be increasing.  To give you a visual of my experiment: apply a load wait an hour maintaining position, increase load wait an hour maintain position, etc. For eight hours.
(3,347 Views)
