Find index of an array value greater than certain number
I am having a curve and I need a starting tangent of it, but random amount of values at start are useless so I need to find threshold, where the actual curve begins. For that purpose I built an array of the measured values and tried to find first value greater than certain number and it's index. I tried several ways to do that posted here on forum, but with no success.
I am having a LW 2009, could sb post a simplest possible VI that just finds first value in array greater than constant, and returns it's index?
And one minor question, is it better to build array of each value or just pull out graph history?
Message 1 of 8
(25,753 Views)
"Threshold 1D array" does what you want.
If you by "graph history" mean to read the value of the graph, then yes that works just fine.
Certified LabVIEW Architect
Message 2 of 8
(25,739 Views)
Well, I tried that, but I am unsure how this will work on real data with some fluctuations (meaning not sorted).
Message 3 of 8
(25,724 Views)
How about "greater than" in a for loop?
Message 4 of 8
(25,719 Views)
Accepted by topic author Adalbertus
I will usually do a comparison of the array, then search the output array for instances of true.
0xDEAD
Message 5 of 8
(25,716 Views)
Tried for loop but the result was somewhat inconsistent, not sure what I've done wrong.
Will try the boolean array.
Message 6 of 8
(25,707 Views)
Just noticed a mistake in this.
"Greater than zero" should be replaced with "Greater than or equal to zero" or it will miss a match if it is the zeroth element of the array.
Message 7 of 8
(25,529 Views)
Here is an alternate method.
Message 8 of 8
(25,508 Views)
