Find home has a problem
I use NI 7334 when I create the home find by Motion Assistant to LabVIEW and then I run it, it stop at home but when I copy the code to my program and then I run my program, it no stop at home, it will stop at its start position.
Thank you mery much.
(2,707 Views)
Hi water2006,
When you copied it over, did you make sure all of your references are correctly set?  If the code in isolation is working, then there might be some problem in the settings that were not carried through.
Vu D
(2,667 Views)
Thank you for your suggestion, I found the setting of master code with copy code mismatch, I set copy code to the same master code and then I run copy code OK.
(2,648 Views)
