Find difference between two numbers (DBL)
Hello All,
Is there a function in labview other than subtraction function that can find the difference between the two given numbers?
Davidson
Message 1 of 16
(5,059 Views)
May be this.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 2 of 16
(5,050 Views)
Is that not still subtraction?
Alan
Message 3 of 16
(5,044 Views)
You could extract mantissa and exponent. Then implement the bit-arithmetics on your own.
Felix
Message 4 of 16
(5,029 Views)
Thanks for the replies..!!!
I tried a VI.
Please find the attached one and let me know if there is any case where it won't work. 🙂
Any suggestion on how to do this better is greatly appreciated!!!
Davidson
Message 5 of 16
(5,018 Views)
You yourself have used subtract function.Smiley Mad
Gaurav k
CLD Certified !!!!!
Message 6 of 16
(5,012 Views)
I think what you are after is the 'Absolute' Value:
This will return the difference as a positive value.
Rgs,
Lucither.
"Everything should be made as simple as possible but no simpler"
Message 7 of 16
(5,003 Views)
Hmmmmm...... Im not too sure if that is what you are after now after running your code???? What exactly are you on about?Smiley Surprised
Rgs,
Lucither
Message 8 of 16
(5,001 Views)
I think if he wanted to find absolute value he would have mentioned it.
And not asked about other function for taking difference.
Do you want to fight over this? Smiley Very Happy When it is mentioned "DIFFERENCE" and not "ABSOLUTE" value.
Anyways..Will fight tomorrow. I am going home.
Best of luck Smiley Wink
Gaurav k
CLD Certified !!!!!
Message 9 of 16
(4,997 Views)
Ok.. 😉 I'll break it down 😉
I expect the difference between two numbers with sign.
In the VI snap, what will be the output for Numeric= (-1) and Numeric2 = (-5)
The output i expect is (-4).
I was thinking of labview function which can give me the exact difference;-)..
Davidson
Message 10 of 16
(4,987 Views)
