Find a VIs subvis programatically
I've decided to put up instead of shutup. I want to write a tool to make it very easy to docment VIs (instead of complaining about the lack of a decent tool). One feature I want is to be able to propagate a control's description and tip down a VI's hierarchy if the controls of the subvi's have identical names. To do this, I need to know the names of the subvis that a VI calls. I can do this by loading the VI and building a tree by looking at all the VIs in memory and examing the caller VIs of all VIs.
Is there is a simple way to directly get a list of a VI's subvis?
(3,402 Views)
Accepted by topic author Jacc
Hi Jacc,
You can use the Invode node method, Get VI Dependencies to list all the sub VIs of a VI.
Nitz
(Give Kudos to Good Answers, Mark it as a Solution if your Problem is Solved;))
(3,396 Views)
Expected it to be property and did not check out Invoke, enven though I use Invoke.for other purposes, but Invoke really does make sense. Many thanks.
(3,372 Views)
