Find Max and min value from excel using labview
Hi
I have data in excel file and I want to find maximum and minimum value from every column.
So please help required
thanks
(3,652 Views)
You can do that within Excel using the MAX() function, you know?  No need to use LabVIEW.
But if you insist on loading the XLS file into LabVIEW, look here:  https://decibel.ni.com/content/docs/DOC-7991
http://www.medicollector.com
(3,641 Views)
Spoiler
(3,627 Views)
Thanks  apok
in your vi case we have to enter raw and column number so is it possible to find Max and min value from every column without any entering of data from our side. Is it possible to find all Max and min value from excel data sheet by one click only.
thanks for reply
(3,610 Views)
Use this library file & give input like number of columns & rows.
Later read the values & store into array. Later use this array and pass it to array max & min & get the result.
Let me know if you have any doubt
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,606 Views)
