Filtre FIR FPGA LabVIEW
I work with labview to filter a signal (attenuation) with a FIR filter, FPGA card and FlexRIO module.
I am new with LabVIEW FPGA.
I tried a simple I / O (without the filter) and I get the input signal, but when i add the filter (I do the configuration and Upload the coefficient file) I do not get the signal anymore.
(3,088 Views)
Hi MyrzaMBM,
First, Welcome to the Forums!
Second, This may be better suited for our Real-Time Measurement and Control board. While the LabVIEW board sees more traffic, that board is frequented by more of our FlexRIO users who may have additional insight.
In addition to moving this thread to that board I would also recommend adding additional information about the hardware you are using including what FlexRIO and what FAM (FlexRIO Adapter Module) you are using. Many differences exist across devices and FAMs and it is useful to know which we are working with in order to understand how best to implement this.
Alex W.
(3,029 Views)
Hello
Thank you for your answer.
I work with NI 5783 Adapter Module.
(3,022 Views)
