Filters Errors
Dear crossrulz
I have found the main reason why the VI is not working but i just cant tell why .
well when i run the VI and it says error at the peak detector . i double clicked the staistics VI and i let it display the number of samples and the time between samples. well the time is right as i configured it . 0.001 BUT the number of samples is giving  only 1 ! eventhough i have collected 25000 samples .
what is causing this ?  i feel like we're very close to the solution .... I am going out of my mind ..:S
Bill David
Message 11 of 18
(1,262 Views)
Have you really captured that many samples (25000)?  Just because your collector is set to that doesn't mean you really have that many samples.
How many iterations of your loop before the error?  Again, if you are only capturing 1 data point per loop, you will have to wait at least 15 iterations before performing the peak detect.
I also question your string to number conversion scheme.  What is the format supposed to be coming from the micro.
Message 12 of 18
(1,258 Views)
ah okay . well  I am using a string to byte array function .and teh output of it is connected to a waveform that displays the signal . so every single byte s drawn here . so yes I am dealing with a single point .
what do i have to do in this case . can you suggest anything to solve this ..kindly 🙂
Thank you .
Bill David
Message 13 of 18
(1,254 Views)
sorry i fogot to answer the other part of the question .
concernin the conversion to a number . if you take a look at the VI you will see that was using a for loop and some stuff to convert from hex values to decimal .but now i am only using a singla function that does all that . it is a string to byte array function . since the microcontroller (16F874  from microchip) sends a word or a byte . so i am dealing with bytes at the serial port .
I hope i made it clear 🙂
Bill David
Message 14 of 18
(1,253 Views)
Thank you .
Ok, since you only have a single byte coming in at a time, you need to hold off your peak detection.  As I stated earlier, use the statistics VI to output the number of samples collected.  If more than 15 samples have been collected you can perform the peak analysis.  If not, do nothing.  Use a case structure.
Message 15 of 18
(1,247 Views)
Dear crossrulz
sorry for the misunderstanding i am making here , i beg your pardon . but i meant to say that the microcontroller sends a stream of bytes at a time . but i just cant know specifically the number of bytes the microcontroller sends .
what to do in this case please
AGAIN sorry :S
Bill David
Message 16 of 18
(1,240 Views)
The solution I gave you is not dependent on the number of samples you are acquiring in each iteration.  Get the number of samples collected.  If greater than 15, then you can do the peak detection.
Message 17 of 18
(1,236 Views)
Does it make sense ?
Bill David
Message 18 of 18
(1,233 Views)
