Filtering arrays
I have a VI setup to read my DAQ board. However the data needs to be filtered. The output of the VI is an array. How can I filter the data? I have attached pictures to help.
(3,156 Views)
Since the data is being returned as a 2D array, you simply have to insert an index array function to extract a single channel's worth of data and wire that 1D array into the filter function that you need.
(3,156 Views)
You can also use the Digital FIR filter or Digital IIR Filter(available only with LabVIEW Full and Professional Development Systems) to filter N channels at a time.
Ankita A.
(3,156 Views)
