Filtering a 2d array and taking average
Hii Friends,
Can anyone help me in sorting out the following issue with my Labview code.
My program consists of the following steps:
1) Opening an already existing spreadsheet having two columns (p and s)
2)Filtering few values in the s column above a threshold value (I my code it is 0.025) and then removing the corresponding p values.
3) Taking a rolling average with 10 point interval
4) Filtering p values in a certain range(0.2489 and 0.273) and extracting the corresponding s values(around 31 values in my code)
5) Lastly, i take normal average of these 31 values. of both p and s.
I have made similar calculation in excel and crosschecked my program. Upto the 4th step, the program code seems to be fine. The problem arises in the 5th step.
The p mean and s mean seem to be right. However, the array size in the last loop displays a value of 992 instead of 31. Not knowing where the misake has been made. Can anyone point out my mistake so that i can correct it.
I am attaching my excel file from where i got the data, the front panel pic and my labview code.
Thanking you
(3,442 Views)
sorry guys..solved the problem myself...
(3,389 Views)
Well, tell how you solved it.
It might help someone in the future with a similar problem who discovers your message thread.
(3,385 Views)
And then mark your own post as a solution so this thread shows as solved 🙂
GCentralI'm attending the GLA Summit!
(3,378 Views)
