Filtering Analog Signals
I am currently using a PXI 6025E board to read an analog signal from a weigh station. The items that are being weighed are in motion so the signal contains some vibration from the item being in motion as it crosses the scale. I would like to be able to filter the analog signal so that I just get the pure weight and not the noise from the vibration. What is the best way to filter the signal using LabView?
(3,547 Views)
One method is to use a "median filter" this is a statistical median of the data you have collected over a brief period of time. Presumably, you will have a good number of cycles from the vibratory motion. Use the statistical function for median. This will sort the data from most to least and produce a number in the middle of the list.
A second method is to use a low-pass filter to filter all data above say 1hz.
A thid method is to use the DC and RMS function and take the DC output of the function.
Try all three to see which produces the best result.
Sincerely,
Preston Johnson
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(3,547 Views)
Another method is the store a number of results and calculate the
average of these points.
Do sample fast to get more data and you will get a better result.
The method with the best results depends on the noise expected, on its
spectrum and amplitude distribution.
Median is fine if you have a lot of good data and a few wrong ones far
away from the 'real' result..
AVG and Lowpass is fine for symetrical noise.
DC / AC is fine in the same case, but the parameters cannot be chosen by
yourself.
Good Luck
Urs Bögli
>motion. Use th
>list.
>say 1hz.
>of the function.
>Sincerely,
>Preston Johnson
(3,547 Views)
yourself.
Good Luck
Urs Bögli
>motion. Use th
>list.
>say 1hz.
>of the function.
>Sincerely,
>Preston Johnson
(3,547 Views)
