Filter to get the peak point
There are many random location and magnitude pulses.
Every one can be zoomed in as an oscillated waveform.
I need to extract one max peak point and one magnitude from each pulse.
Any suggestion?
Sometimes 2 pulses may quite close.
I tried WA peak detection, not work well.
(2,670 Views)
You provided a binary file, but you didn't specify what it was, nor what kind of data was in there. It seems to be an array of SGL values.
I don't know what the "WA Peak Detection" VI is. I only know of the built-in "Peak Detector" VI. What parameters are you using for it?
(2,650 Views)
