Filter illegal characters
I'm trying to filter illegal file name characters using an event structure.  At the same time I don't want a legal character to be displayed more than once if a key is held down continuously.  I've tried KEY DOWN? and KEY REPEAT? and I can't get my desired results in either case. See the attached.  Thanks in advance.
(5,697 Views)
If you have a string control you can right click and select the option "value change while typing" or something along those lines. That will cause every time the string is changed to create a value change event.
(5,685 Views)
You only have a fitering event for "key repeat?. You also need to add a "key down?" fitering event to the same event case.
(You can delete the timeout case. You should also initialzie the shift register).
(5,675 Views)
Accepted by topic author AT1
(5,670 Views)
Excellent!  Thanks for your help.
(5,623 Views)
