Filter Express vi building appllication problem.
Hello!
I have a problem with Filter express vi or I think it's the reason for my problem. My application runs ok, but after I compile an exe it won't. When I run my exe, it shows open dialog and says (Please find the VI named"Instance 6 20Saved WFA_08042004 .vi"). WFA_08042004 is my applications name.
And this not the only program all those were I have used filter express vi have the same kind of problem.
Notice "Instance 6 20Saved WFA_08042004 .vi" differs if I use different application.
I have Dell latitude C640,labview 7, win xp servicepack 1, sc-2345 (Module FT01), DAQCard 6036E.
Neuvos
(2,855 Views)
Neuvos,
This problem with the Filter express VIs built into exeuctables has already been reported to LabVIEW engineers, and they are working on a solution.
For now, a workaround is to convert the particular filter express VI into a regular VI. To do this, right-click on the express VI and select Open Front Panel. Select Convert in the dialog window. Then just save the opened VI into your project directory.
Zvezdana S.
(2,855 Views)
HI!
My problem was in low and upper cut of frequencies. When I set them so that they crossed for example: lower 50 Hz and upper 49 Hz, the problem occur. When I set the program so that the limits can't cros --> everything works fine.
Neuvos
(2,855 Views)
Neuvos,
Thanks for this feedback. Yes, we are already aware that the problem is with the frequency limits, but only when the VI is used as an express VI. Converting it to a regular VI, even with those limits, resolves the problem.
Zvezdana S.
(2,855 Views)
