Filling a Tank
Hello I am new to LabView software and got stuck in a simple problem (although confusing for me...).
The filling of a graduated tank from 0 to 100 by a step of 20 in each 100 ms with a timing indicator.
I was able to fill the tank however could not think a way to time its increment "by a step of 20". Could you please help me out?
(1,977 Views)
Hi Jo,
So why don't you attach your current VI? (Do you really think we will do your homework for free?)
Hint: when something (aka the same operation) is done be several steps (aka in a repeated way) then you should use a loop.
Hint: To remember a value from one iteration of a loop for the next iteration of that loop you should use shift registers…
(1,971 Views)
Please share the VIs you have created so far for the forum members to guide better.
P.S. - it is LabVIEW not LabView
Santhosh
Soliton Technologies
(1,968 Views)
I am sure we can tell you what you are doing wrong once you attach your VI.
Time is a very important component of LabVIEW, and there is an entire timing palette. Try to find something that would help you.
Is this a real tank where you controls valves, etc. or a simulate tank on the front panel?
(Have you used any of the learning resources listed at the top of the forum?)
(1,967 Views)
attaching my VI here...
(1,959 Views)
Sorry, I don't have LabVIEW 2021 here. Consider "save for previous" before attaching.
(1,944 Views)
And one more thing, very few of the forum members have LV2021 on their machine to open the VI. You will cover a larger audience if you share the VI in 2016 version.
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/dialog-boxes/save-for-previous-version-dia...
Santhosh
(1,940 Views)
