Fill array with formula nodewith one line of code
This is my first post to NI community, maybe this question has been asked 1000 times but I could'nt find any answer.
Before using LabView I used Matlab a lot. I kinda find it too complicated for no reason sometimes in labview to work with arrays.
I inherited and I'm trying to do some clean up. what this does is extractr the 2 and 3 position and creates a new array with it and another oner with the others elements of the first array. I find it gets confusing because you have to count on the array box the position of the output and I don't wat to work that way.
I replaced this with a formula node. Here's the code
The starting array is FP, the 6 elements array is mdot and the 2 elements array is press
float64 mdot[6], press[2];
mdot[0]=FP[0];mdot[1]=FP[1];
mdot[2]=FP[4];mdot[3]=FP[5];
mdot[4]=FP[6];mdot[5]=FP[7];
press[0]=FP[2];press[1]=FP[3];
Now I want to know if it is possible to do like I would in matlab or C, where you can create an array with one line of code. What would be the syntax in formula node to do something like:
mdot[6]=[FP[0],FP[1],FP[4],FP[5],FP[6],FP[7]];
press[2]=[FP[2],FP[3]];
Message 1 of 16
(4,783 Views)
Accepted by topic author BassBijj
Use Delete From Array.  You can supply an index and length of elements to remove.  One of the outputs will be the original array with the subset deleted and the other output is the deleted subset.  1 NODE!
EDIT: Created a snippet right after my previous post.
GCentral
Message 2 of 16
(4,774 Views)
Hi Bassam,
that's how your one-liner looks in LabVIEW:
Message 3 of 16
(4,772 Views)
Thanks for the answer I will use this before my calculation in the formula node, but lets say I REALLLLY want to code it, is what I'm asking possible ?
Message 4 of 16
(4,769 Views)
I'm not sure what you are asking.  We just showed you how to code it for real.
GCentral
Message 5 of 16
(4,760 Views)
Hi Bassam,
why do you want to "clean up" LabVIEW code by using a rather slow formula node - when pure and simple G code is available?
Message 6 of 16
(4,759 Views)
In this case the two value to extract where 2 and 3 position but if they were 2 and 5 I would have needed to use 2 delete from array..and so on depending on the first array...
I find it more clearer to use a formula node because you don't need to count the very small wire output you just see it in the formula node code. Now if formula node are slower I wasn't aware of that..how much slower are they really ? I understand this way (formula) might not be the most efficient..but is it this bad or you just prefer the graphical solution ?
I knew the solution by using the delete from array bloc...but I don't know how to code it in a formula node in one single line like I specify in my first post.
Is it possible or not ? What is the syntax if it is possible ?
Message 7 of 16
(4,737 Views)
Message 8 of 16
(4,736 Views)
Hi Bassam,
when the number and index of those elements are variable you would use a loop and employ autoindexing…
You don't need to count any IndexArray outputs for this task:
LabVIEW is a graphical programming environment. Why do you even choose LabVIEW when you don't want to use that language?
The formula node uses a C-like syntax. The help explains the accepted commands. Why don't you try this on your own?
When there are syntax errors the compiler will point you on them…
Message 9 of 16
(4,714 Views)
Thanks for the quite elegent graphical solution,
Why do you even use labview...?
I could simply return the question ..Why would labview include formula node since it is a grapical programming environement ? If its not slower and gets the job done why wouldn't I use it ?
Personnaly I think it is  more simple to use a formula node where you create and X array by filling it with any elements of an Y array...
X=[first element of Y, third element of Y, sixth element of Y] for example..
I wouldn't have been able to produce the solution you showed me on my on..it's quite unintuitive for me..and I still don't get why you reverse before the loop and after...is it to start splitting the array from the bottom ?
it is the only time I wanted to use the formula node and I've tried to look in the help before asking question. I was sure it had something to do with synthax, something that would have been easier for some others since I dont really know C either..I've only used Matlab in the past and syntax is way different..
Message 10 of 16
(4,694 Views)
