Filename too long in build
So I just tried a build in 2009 and got a curious error:
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 6 occurred at Create Folder in Create Directory Recursive.vi->AB_Destination.lvclass:Create_Destination.vi->AB_Build.lvclass:Create_Destinations.vi->AB_Application.lvclass:Create_Destinations.vi->AB_Build.lvclass:Build.vi->AB_Application.lvclass:Build.vi->AB_EXE.lvclass:Build.vi->AB_Engine_Build.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW:  Generic file I/O error.
NI-488:  I/O operation aborted.
C:\Projects\VI Engineering\Software Products\1-09-xxxxx - VI Engineering - Hardware Explorer\Engineering\5 - Release\Executable\VIE Hardware Explorer\VIE Hardware Explorer.exe\LabVIEW 2009\user.lib\_VIE Internal Reuse Library\_vie_lib_dialog_&_user_interface.llb
Due to operating system limitations, LabVIEW cannot create the folder because its complete path contains too many characters.
The files that it's complaining about are going to be inside the exe, so why is it an issue?  Surely the filename length check should stop at "C:\Projects\VI Engineering\Software Products\1-09-xxxxx - VI Engineering - Hardware Explorer\Engineering\5 - Release\Executable\VIE Hardware Explorer\VIE Hardware Explorer.exe", which is well under the Windows filename length limit, right?
Copyright © 2004-2024 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
Message 1 of 26
(6,827 Views)
Even curiouser - changing the "Advanced" build option "Use LabVIEW 8.x file layout" seems to fix the issue...
Message 2 of 26
(6,823 Views)
This is a known issue with Windows95 😉
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 3 of 26
(6,821 Views)
The app builder in 2009 builds the EXE as a ZIP which maintains the folder hierarchy internally (which you can actually see in the message) and acts as a virtual folder, so the file name length limitation applies. This also explains why it doesn't happen if you use the 8.x switch.
Another place where you should be careful is if you strip a path in a loop until you reach a folder. Because the folder hierarchy is maintained inside the EXE, it means that the strip will most likely end while still inside the EXE.
___________________
Try to take over the world!
Message 4 of 26
(6,801 Views)
P.S. I'm not sure if this limitation applies once you build the actual EXE, but one way of working around it during the build is to direct the build to a folder like c:\build.
___________________
Message 5 of 26
(6,796 Views)
To further what Tst said, during the build process Application Builder literally creates a folder containing your VIs in the final EXE layout before zipping this folder into the EXE. (if you have a look at your destination folder during the build process, you will see it), hence why the restriction holds even though the final path inside the EXE is not a problem.
The reason 8.x layout doesn't have this issue is that the intermediate step for 8.x EXE's is to create a LLB instead of a physical folder.
Shaun
Message 6 of 26
(6,781 Views)
I understand why this is happening (LabVIEW is struggling with the filename length limitof temporary files during it's build) - but I still think that has nothing to do with me - shouldn't it just build somewhere further toward the root (in, say, a temporary location?  These files are, afterall, temporary).
Message 7 of 26
(6,768 Views)
Cross-posted here.
Message 8 of 26
(6,767 Views)
The issue with saving the "temporary" files in a shallow directory structure (C:\temp for example) is that this causes problems when files are located at destinations external to the application. For example, take a sub VI located the default support directory referenced by a VI that is in an EXE. When all the links are updated, if the temporary location is not relative to these destinations, LabVIEW may end up searching for the VI. If the files are all kept in directories relative to the destination location, this is not an issue.
George M
Message 9 of 26
(6,742 Views)
I still stand by the comment that this is a bug.  The build fails.  Yes, there are workarounds, but the users should have to use them - the builder should know that there's going to be an issue during the build and change it's behaviour to fix it.
Message 10 of 26
(6,600 Views)
