File name and Measurement in the same table?
I have written the following VI that opens up each image file from a folder and measures a certain dimension on the image. It then puts the result of the measurement in a table.
The table has one column and N rows since I have N images in my folder. How can I modify this VI so that it puts the filename in the same table as well as the measurement?
I want the table to look like:
filename1 measurement1
filename2 measurement2
and so on.
Currently, it just shows
measurement1
measurement2
and so on.
Here is the VI:
(2,879 Views)
Accepted by topic author HA1975
You can't use the Express Table. As the properties page says, it is for numeric data. You will have to use a little bit of actual LabVIEW to create the table. A table is just a 2D string array. So, convert the numeric to a string, build a 1D string array from the file name and numberic, and use a shift register to build a 2D array. Something like the code below.
Message Edited by Dennis Knutson on 05-07-2009 01:43 PM
(2,871 Views)
Thank you very much! That worked exactly like I wanted to.
(2,850 Views)
