File Structure
Hi all,
I have all my code in the structure below at the moment (many links among vi in the folder):
c:\LVCode\Test\
If I were to move all my codes, so that they all resides in the location below:
c:\ABC\CDA\LVCode\Test\
Could all the vi in the folder that are linked together have broken links?  Would LabVIEW be able to fix such a small difference in the file structure?  Thanks!
Yik
(2,907 Views)
VIs are linked to different VIs via relative paths (unless the other VI is inside user.lib/vi.lib)
So you should have no problems.
Ton
My LabVIEW Ideas
(2,892 Views)
That's a sound of comfort.  Thanks!
yik
(2,883 Views)
