File Paths on Real-Time Target
Is it possible to change the path in RT system.
By default the Drive:C,can I change the letter to E or D
AB
Kudos are Accepted
(2,934 Views)
Hi Vara,
the RT system (cRIO?) usually only has one (internal) drive, which is named "C:".
No, you can't change the name here...
(2,891 Views)
