File Path Control question
Simple question: How do I invoke the Open command in the File Path control? My reason is of my user hasn't supplied a file, then I want to force the user to select one.
(2,860 Views)
Accepted by topic author Eric1977
Most file related vi should prompt if there is no file path. If for some reason you are not getting that you could check to see if the file path is empty and add a prompt see below:
Tim
GHSP
(2,859 Views)
That worked. Thank you!
(2,855 Views)
