File I/O does not save elements in array
I cannot seem to save the elements in the array. If I stop the program and restart it, the array starts from 0 again. I want it to start from the value it stopped at.
Is it a shortcoming in the SubVI "Timer A1"?
Thanks for the help.
mhaque
Message 1 of 18
(5,811 Views)
Use the "Set File Position" function and set it to the end after the open and before the first write.
Omar
Message 2 of 18
(5,799 Views)
Hi Omar I did as you told, but it does not seem to work.
Message 3 of 18
(5,792 Views)
No you didn't.  He told you to set it to "end".  You have it set to "current".
Message 4 of 18
(5,780 Views)
I did set it to "end" but but it still did not work. Should I use a different file format or is there something instrinsically wrong with my code?
mhaque
Message 5 of 18
(5,776 Views)
Accepted by topic author mhaque
Your Feedback Nodes are set to Globally Initialize on the First Call, as evidenced by the glyphs.  If you are stopping and starting your program, they should be set to Globally Initialize on Compile or Load, just Right-Click and change the setting.  This should give you the behavior you are looking for, but does not rule out intrinsic problems with the code.
Message 6 of 18
(5,763 Views)
Try again.  It works for me.  The only other thing I did was set the file open to "open or create" and disable the reading part that you have outside the loop since I didn't have your existing file.
Message 7 of 18
(5,760 Views)
The VI works for me well but I still have a few queries.
Firstly could I use the SubVI "Timer A1" as rentrant?
Secondly if I close the program, the timer again starts from 0. How do I make it start from the time I left it at when I close the program?
mhaque
Message 8 of 18
(5,708 Views)
You will have to save the time to a file and then read it in again at the start of your program.
Omar
Message 9 of 18
(5,703 Views)
I put in the following code. It still does not work. Perhaps I made a mistake.
mhaque
Message 10 of 18
(5,698 Views)
