File/Directory Info
my code is causing an issue here...using the File/Directory Info, when no file is found, i want to ignore it and not have the pop up...
can someone please help me..a diagram would be greatly appreciated..
i dont know how to fix it because i really don't understand how this VI give out the error, and I dont have very well understanding of the simple error handler...
i was going through the forum and found this infomation that is useful
"To avoid the pop-ups all you need to do is wire the error cluster and handle the error. In this case, check the error number.
If it is an error you want to ignore, pass an empty error cluster on. If you don't want to ignore it, pass the original error cluster.""
thanks in advance..
Krispiekream
(2,782 Views)
duplicate post
Please keep discussion to original thread so people know what's being discussed
(2,777 Views)
