File Dialog express VI alters error chain
today I've got a strange error message form the File Dialog express VI (with the name New Folder Dialog😞
Error 1055 occurred at New Folder dialog->Check if directory exists.vi->configure directory path.vi->load FP config from file.vi->Triax program.vi
Possible reason(s):
LabVIEW:  Object reference is invalid.
after some research I found out, this VI isn't the source of the error, it just altered the information received from the error in terminal.
Is this a known issue in Labview 2011? I didn't find anything about it.
Message 1 of 8
(5,750 Views)
Accepted by topic author gerh
The way express VIs work is that they generate an actual VI which will be run every time you change the configuration and that VI is saved as part of the calling VI. You can look at the generated VI by right clicking the VI and selecting Open Front Panel, which will ask you if you want to convert. If you do that and look inside the actual VI that it calls, you will see that it makes an unconditional call to a VI which modifies the error chain. I would argue that this call should probably not be made if there the error in was true, so I would call this a bug.
In practice, I would say the best option is either to call the file dialog primitive yourself or to call Merge Errors and put the original error wire on top or wrap the entire express VI in an error case structure.
___________________
Try to take over the world!
Message 2 of 8
(5,678 Views)
Hi tst,
indeed NI reccomends not to use express VI's in final code, the File Dialog is an exception to this.
The documentation says:
LabView no longer supports this function on the block diagram. National Instruments recommends that you use the File Dialog Express VI instead.
I've marked Your answer as solution, but the question if this bug is known is still not answered. I'll make a bug report anyway.
Message 3 of 8
(5,610 Views)
Where do you see that recommendation? Lots of express VIs are used in final code. There shouldn't be any recommendations against that that I know of.
This looks to be a bug in that one VI.
Message 4 of 8
(5,593 Views)
I do know that the file dialog in LV2010 is buggy. I was able to reproduce an incidious one that bit me like a scorpion!
(If anyone really needs to know I will try to dig it up)
I am not sure if it was fixed in 2011 but it apparently was in 2012 since my demo did not show the buggy behavior.
Message 5 of 8
(5,574 Views)
We reproduced the bug in LV 2015.
Message 6 of 8
(5,558 Views)
Hi all,
their has been a CAR (Corrective Action Request) filled out with this issue.
The number to look after in the bug fixes will be the 539895
best regards
Michael
Message 7 of 8
(5,517 Views)
CAR 539895 has been fixed in LabVIEW 2016. For more details, please see the LabVIEW 2016 Bug Fix List.
Message 8 of 8
(5,151 Views)
