File Dialog Function no Longer Support Datalog Files
how do i get rid of File Dialog Function no Longer Support Datalog Files?"
Message 1 of 14
(4,851 Views)
Accepted by topic author 0164650276
Ummm.. could you repeat your question please? With a little better explanation? As it is, I have no idea whether you're asking if it does support it, or whether you're complaining that it doesn't, which I don't understand, since the File Dialog is just for selecting files. Are you aware of the Datalog functions?
Message 2 of 14
(4,848 Views)
This is the problem promp out.
Anyone can help me out ?
Message 3 of 14
(4,835 Views)
Message 4 of 14
(4,830 Views)
I am assuming you accidentally clicked the "Mark as Solution" button ...
That screenshot indicates you actually have a warning, not an error.
I am also assuming you are upgrading old code, such as code from LabVIEW 6 or somewhere around then. At that time the File Dialog had a "datalog" input. The File Dialog VI no longer has that. If you are dealing with datalog files you should update your code to use the explicit Datalog file functions in the File I/O -> Advanced File Functions -> Datalog.
Message 5 of 14
(4,804 Views)
Hi, knight of NI. basically i also having the same problem. my code is exactly extract from someone who used labview 6.1 version and tried on my labview 8.6 version.
according to your method to solve this issue, i cant find where is the file i/o located at.
Thanks!
Message 6 of 14
(4,791 Views)
this is the print screen of the program function that we are going to use for measurement.Untitled.jpg
Message 7 of 14
(4,790 Views)
I had given you the path for them. See attached screenshot. Did you look in the LabVIEW Help?
What is the front panel supposed to show me? It doesn't say anything about the actual code that you are using.
I'm not sure what your question is now. As I noted, the File Dialog doesn't have the datalog input anymore, so you have to change the code to use the Datalog functions. The LabVIEW Help has a page on reading from datalog files: https://www.ni.com/docs/en-US/bundle/labview/page/reading-from-datalog-files.html
Message 8 of 14
(4,745 Views)
Hi. Can you help me to check the code?
Here is the file that I'm using
labview
Message 9 of 14
(4,729 Views)
Why would you use some odd hosting site. Just attach the VI. Clicking on 'Add Attachment' should be pretty obvious.
Message 10 of 14
(4,725 Views)
