Fieldpoint counter read timing problem
I am having a problem with the fieldpoint FP-CTR-500 counter under Bridgeview.
I need to read and reset the counter channels at a fixed rate from 100mS to
seconds.The tags are not being updated at the rate set for the I/O Group Update
Rate. If Fieldpoint explorer configures the module for a different update rate
which rate is used?
Message 1 of 1
(2,807 Views)
