FieldPoint support with System Configuration
system: LV 2009 SP1, FieldPoint 6.0.9, cFP-2220, LVRT 9.0.1
Does anyone know if any of the versions of NI System Configuration VIs support the FieldPoint platform?
Neither FP6.0.9 (shipped with Aug-2011 System Media) nor FP6.0.10 appear to load the SysCfg support library onto the RT system so the host-side VIs are of no use in polling the RT.
Dave
(and yeah, I know, old system - do an upgrade ....)
(2,652 Views)
I would suggestion using NI System Configuration 5.4.  The main problem is that you are using LVRT 9.0.1, and I believe that SysConfig 5.4 was the last version to support LVRT 9.x.
http://joule.ni.com/nidu/cds/view/p/id/3667/lang/en
In general thought it should work with a cFP.
(2,630 Views)
