FieldPoint analog input to Signal processing
I have a new FieldPoint Analog input device installed, and addressable via LabVIEW DSC. I want to use the signal processing tools to analyze the input data. Specifically, I have a function generator connected to the analog input, and want to analyze the input signal through the "Tone Measurements" Express VI.
I keep having trouble with getting data types to properly convert. When I read the DSC Tag, I get a DBL (Double Precision) value. The input to the "Tone Measurements" Express VI is Dynamic Data Type (DDT).
How can I include timestamp data in that stream in a meaningful way? Or, alternatively, how can I convert the DSC tag output into a dynamic data type (DDT) or signal??
I have attached a half-working vi,
but it is neither smooth nor accurate and the Tone Measurements express vi doesn't output meaningful information.
(3,083 Views)
The Tone Measurements Express VI assumes the input will be a waveform. You can use the Collector Express VI from the Signal Manipulation palette to collect individual points into a waveform. I would try this first.
If that does not work for you, you may need to use the VIs in the point by point palette. Do a search on the palette for "point by" and it should be the only one that comes up.
(3,083 Views)
