FieldPoint Startup Program Not Running Correctly without Front Panel
My program runs correctly when I have either the Front Panel open or the Remote Front Panel open in a web browser
What the program is supposed to do is cycle through some LED's on the FP-2000 and then wait for either a user command to turn on some fans or a digital input to turn on the fans for a specified amount of time, however when there is no front panel open and a digital input is received the four fans turn on then turn right back off.
can anyone explain this
thanks
(2,720 Views)
Try writing to local variables of those controls and indicators rather than to the value property node.  I believe on cFP RT systems, the front panel is stripped from the system, so the value property nodes can't be used as a place to set or access the values of those controls.
(2,697 Views)
That was it thanks for the help
(2,678 Views)
