Field Point Data logger reading all zeros
Hey everyone,
I have a question about using FP Datalogger with Graph. We use it to monitor thermocouples and pressure transducers. Anyways normally it reads fine and there are no problems. Sometimes however, the data will drop out completely and read all zeros. This happened recently and I opened up Fieldpoint explorer and checked it as well and it was reading fine at the same time that the FP graph was reading all zeros. Has anyone had experience with something like this? What did you do to correct it? For reference we are using
Labview DSC 6.1
Fieldpoint Explorer 3.0.2
Thanks in advance!
(3,702 Views)
Anyone encountered this before?
(3,691 Views)
What version of LabVIEW are you using?  Furthermore, what Fieldpoint devices and modules are you using? Does the FP device read all zeroes at random times or always drop off at a specified time?
Nadim
Applications Engineering
(3,682 Views)
Hi Chris,
Did you ever find a solution for this problem? I'm working with an application that does the same thing - read zeroes all of a sudden. If you remember what caused the problem and/or what solved it for you, I'd really appreciate hearing it!
LaRisa
Product Support Engineer
(2,772 Views)
