Few Queries on Calling Excel in LabVIEW
1. When  calling Excel Using Automation Open, and Giving Visible as False its works Perfectly in my development PC but when i am using the same code in My Lab PC its Physically opens the Excel which i dont recommend.
Only Difference i see is my PC RAM is 32GB whereas the Lab PC is having 16 GB
Selected only a part of code from the actual code so error in the PICTURE
2. Assume i need to select a column in my excel i cab click the Top of column and Do any action particular to that column like the same i need to do programmatically without providing  range Selection (Cell1 and Cell 2)
LabVIEW Version 2015
Thanks in advance
(3,357 Views)
If you have access to the Report Generation Toolkit, working with Excel becomes very easy (as opposed to moderately challenging).  In particular, you can choose to make a New Report (Excel) in Normal or Minimized mode.
(3,308 Views)
1. Are you using the same Office version on the lab PC? Is the development code installed or are you using an executable?
2. You must provide a range selection to select a column but you don't need to write values in Cell1 and Cell2, if you set Cell1 to F:F the sixth column will be selected.
Ben64
(3,306 Views)
@ ben  officve verrsion is same in both the PC's and the problem is in Development Environment later i need to call as Run time Adopter Module in TestStand
Thanks that i can able to select a whole column.
(3,279 Views)
