Fehler-200077
Hello Friends
i want to use the attached Vi to drive a DC-Motor contolled by a DC-Servo-Controller (including a transformer and a rectifier) which then drives a Spindle Pump for generation of high pressure ca 4000bar, control a Laser Machine 0V-5V (Diode-Laser) and collect pressure reading from a High-Pressure-Transducer (P3MBP BlueLine from HBM). However got Error - 200077 on testing the programm. during debugging i observed the problem starting from the Sample-Clock sub-Vi, unfortunately i cannot find solution to the problem. am therefore asking for help!! am working with LabV. 8.0 and PCI-M6221 card from NI. the Signal from AO is a Ramp-Signal
thanking all in advance
(2,686 Views)
Looking at the upper sample clock, it looks like you have the 2 constants reversed.  You have a 2 going to sample mode (probably the cause of the error) and the finite samples going to the Number of samples.
(2,664 Views)
