Fatal error: protocolsup.cpp
This problem is just happened to me. This is the log file.
First it happened when I set the breakpoint. After I found this forum, I tried to remove the breakpoint but the LabVIEW still crashes. It's so dissapointed.
It happens at line 3244. From now on, I cannot run the code anymore T_T.
#Date: Mon, Apr 14, 2008 3:44:16 PM
#OSName: Windows NT
#OSVers: 5.1
#AppName: LabVIEW
#Version: 8.5
#AppKind: FDS
#AppModDate: 07/25/2007 02:07 GMT
c:\builds\penguin\labview\branches\Jupiter\dev\source\server\protocolsupp.cpp(3244) : DAbort: MakeSyncCallEx: No available slots for opcodesent:77 27=kOpSetVIState, waiting for 1132=kOpSetInstrStateAck
sent:78 27=kOpSetVIState, waiting for 1132=kOpSetInst
$Id: //labview/branches/Jupiter/dev/source/server/protocolsupp.cpp#57 $
0x00F4C898 - LabVIEW <unknown> + 0
0x00AE5096 - LabVIEW <unknown> + 0
0x00874723 - LabVIEW <unknown> + 0
0x005E1C4B - LabVIEW <unknown> + 0
0x0049C139 - LabVIEW <unknown> + 0
0x0049A981 - LabVIEW <unknown> + 0
0x0049C1EC - LabVIEW <unknown> + 0
0x00405678 - LabVIEW <unknown> + 0
0x0040599B - LabVIEW <unknown> + 0
0x0041EDB0 - LabVIEW <unknown> + 0
0x0053EC85 - LabVIEW <unknown> + 0
0x00F4E9C6 - LabVIEW <unknown> + 0
0x00F4C069 - LabVIEW <unknown> + 0
Message Edited by THANG NGUYEN on 04-14-2008 03:57 PM
Message 31 of 34
(1,456 Views)
Something I just found out (a year and 4 months after I first asked about this problem). I am using LV-realtime talking to LV-fpga on a PXI chassis. I made the mistake of putting a breakpoint in the RT code and got the problem back. It wouldn't go away until I shut down and restarted the PXI chassis.
So you might try rebooting to see if the problem goes away.
Still mighty anoying though.
Chuck
Message 32 of 34
(1,445 Views)
@cgantz2000: Thank you, I restarted and it runs now. It's sweet ^__^.
Message 33 of 34
(1,442 Views)
Yes, i am experiencing the same problem now. I am using RT8.2.1. When this happened, I really don't know what trigged the problem. Now I think it should be the Breakpoints sitting in the blocks because I have set some breakpoints to debug the program. but anyone have some idea how to solve it. We still need the breakpoints to debug problem, don't we?
Message 34 of 34
(1,389 Views)
