Fatal Internal Error drawmgr.cpp 2961
Hi
The application which i had developed was running fine, had used the help icon, where it displays how to resolve any errors when the vi does not function bcoz of some error. Now when i run my vi it displays " Fatal Internal Error" Drawmgr.cpp line 2961" where i have to reboot my system. i tried removing & running the Vi but still the error remains. can u hep me sort out this . Iam using Labivew 7.0
Cheers
(2,646 Views)
Hello suresh.r,
Thank you for your question regarding a LabVIEW internal error. You mentioned that the error only occurred after using a help icon but removing is has not helped. There are a couple of scenarios that could be causing the error that you are seeing. Most likely one or more objects on the front panel are causing the video card to return this error. One possible solution may be to try disabling acceleration of your video card or installing newer video card drivers however you may want to read the following documents on trouble shooting this error.
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/01b186b5ceb1d07786256747000f4319?OpenDocument
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/16cf1334d094a4f6c1256be3
0074b9fe?OpenDocument
Other resources can be found on the ni.com website by clicking the support tab at the top of the home page. Then search from Technical Resources at the top of the page for your topic. I hope these resources help! Let me know if you need any other support with this issue.
Shea C.
Applications Engineering
(2,646 Views)
