Fatal Error - LABVIEW.LIB was not called from a LabVIEW process.
After creating an installaion program, I tried testing the install of my app.  The application user interface appears with a Fatal Error dialog box stating LABVIEW.LIB was not called from a LabVIEW process.
Other information on this forum regarding a LABVIE.LIB error, usually mention some types of .dll calls, I have no such calls in my application so I'm curious if anyone else has a similar problem and hopefully a solution.
Development machine and test install system both XP Pro
Using LabVIEW 8.0.1
Thanks in advance.
Con
(2,990 Views)
Con,
      Tell us more about what your application is doing.  Was it working fine until you added a certain portion of code?  Can you reduce your code down to the bare minimum that gives the error?  Does it occur on both of your machines?  When does the error occur?  If you run your VI with highlight execution on, where does the error happen?  Does it happen when you are trying to build an executable?
NathanT
(2,977 Views)
