Faster build
I have an application with around 300 vis. Making an executable with
application builder is somewhat tiresome (takes me around 5 min to
build on an PIII 450). Is there anyway that I can precomile some vis to
make the build faster?
/Nimrod
PS. I'm using LabView 5.1.1
Sent via Deja.com http://www.deja.com/
Before you buy.
(4,006 Views)
Yes there are some techniques but it will take more than 5 minutes to
implement... After all one need to compile once in a while when the code is
completed
Maybe if you tell exactly why a 5 min. compilation time bothers you, we can
find solutions.
Do you compile frequently your code just to see how it runs stand-alone?
Jean-Pierre Drolet
a écrit dans le message :
8eugs9$o9l$1@nnrp1.deja.com...
> Hi,
> /Nimrod
> Before
you buy.
(4,006 Views)
The thing why the 5 minutes bothers me is that I don't get the same
results in the stand-alone version as in the "LabView" environment.
This means I have to make a change, rebuild, and test the stand-alone
to find a work-around. Even with a relatively short compile time it
will become a long time if the app is hard to debug.
In Visual C++, for example, I'm able to make a precompiled header so I
only have to compile what I have changed, but I'm missing this feature
in LabView.
/Nimrod
In article <3912d113@newsgroups.ni.com>,
code is
> completed
> Maybe if
we can
> find solutions.
alone?
> Jean-Pierre Drolet
> > Hi,
vis to
> > /Nimrod
> > Before you buy.
Before you buy.
(4,006 Views)
OK...
Here some project management tips
I'll assume you are on Windows
First, the compiled VI code is already present in the VI file (or LLB). What
the builder do is to recover all VIs needed to execute, copy them in a
single file, remove diagrams, front panels, change settings, etc. It
recompiles the copies because all these changes, but the source VIs are
compiled and executable as is.
To quickly see how your VIs execute in the Run-Time environment, you can
built an empty application (run the builder with *NO* files at all). Call it
LVRT.EXE and put it in the LabVIEW directory. When you execute LVRT, it
opens a dialog asking which VI to open. If you open and run your application
main VI, it should execute quite the same way as in the LabVIEW environment
since the VIs haven't been copied or modified. NO compilation, NO build, you
don't even need to close your VIs in LabVIEW to test the changes, just
reopen the main VI with LVRT. Make a shortcut "c:\labview\lvrt.exe"
"c:\myproject\mainvi.vi" to get things faster.
The main idea is that the Run-Time executable does not require the VIs to be
built but only have to know where to locate them. Of course, problems occur
mainly when the application is really built and the directory structure of
the application is different than in the development environment.
If a large part of the hierachy of the project is quite debugged, you can
make an LLB, using "Save with options" and save VI for distribution, the
same way LLB were prepared for the builders before version 5.1. When
building the application, include this LLB as a *support* file. The builder
does not process support files at all and only copy them to the application
target directory. You have to be sure that the Run-Time application will
know how to locate these VIs, putting LLB path in the search paths list or
calling VIs within using the VI server. Saving VI for distribution is a kind
of "prebuild" and make a part of the work that the builder does not need to
redo every build.
If you have more questions, feel free to repost.
Jean-Pierre Drolet
a �crit dans le message :
8euvho$9lj$1@nnrp1.deja.com...
> in LabView.
> /Nimrod
> code is
> > completed
> we can
> > find solutions.
> alone?
> > Jean-Pierre Drolet
> > > Hi,
> vis to
> > > /Nimrod
> > > Before you buy.
> Before you buy.
(4,006 Views)
Thank you!
This was a great help.
/Nimrod
In article <3913232c@newsgroups.ni.com>,
> OK...
LLB). What
are
can
Call it
it
application
environment
build, you
VIs to be
occur
structure of
can
the
builder
application
will
list or
a kind
need to
> redo every build.
> Jean-Pierre Drolet
alone
so I
feature
> > in LabView.
> > /Nimrod
minutes to
the
> > code is
> > > completed
you,
> > we can
> > > find solutions.
stand-
> > alone?
> > > Jean-Pierre Drolet
> > > > Hi,
with
to
> > vis to
> > > > /Nimrod
> > > > Before you buy.
> > Before you buy.
Before you buy.
(4,006 Views)
Not to say that this is a long time, I still remember when it took 4 to 6
hours to compile programs to exe's I have a Visual C++ program that takes
about 30 minutes to make an exe if I rebuild all.
Work Email: harmon-j@gouldis.com
Personal Email: harmonj@bright.net
Home LandLine: 330-848-0460
Work Land Line: 216-328-7113
wrote in message news:8eugs9$o9l$1@nnrp1.deja.com...
> Hi,
> /Nimrod
> Sent via Deja.co
> Before you buy.
(4,006 Views)
